Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-19T23:31:02+00:00
    I'm not sure how I feel about being a beta tester with a laptop that I depend on for work.
    Any thoughts on how long it might be before they're ready to release this to everyone?
    2019-09-19T18:49:55+00:00
    at the moment, I could switch off the SF6 only for 30 minutes.
    after inclusion observed the same 100% of a charge of the battery.
    tomorrow I will be able to give more exact information
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-19T18:36:45+00:00
    Yes, I just got confirmation that Microsoft used 1796 for both SP2017 (5th generation) and SP6. They always had discreet/separate model numbers for previous WiFi models.
    2019-09-19T18:27:23+00:00
    1796 - it is not model, but the option designating that I have WiFi the module
