Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-10T11:25:29+00:00
    You can use the Get Help app and connect with an agent on chat or call. If your device is still in warranty, they will offer to give you a replacement, as they did for me 2 times now. However, yesterday they said that they can get me yet another replacement, but that I should wait because they are already working on a fix that will be released soon.
    2019-09-10T10:22:02+00:00
    Thanks for the info. I'm from Germany, could you please explain what kind of agent this was? Thanks.
    2019-09-10T07:06:07+00:00
    I spoke with an agent yesterday. She acknowledged that this is a bug that will be fixed in the forthcoming updates to the Surface firmware. This is the 3rd device I am using (after 2 replacements) and it seems now that they are already working on a fix. This is first time when the agent has admitted this. Until now, they would always suggest that I get a replacement.
    Now I'm hoping the update comes soon.
    2019-09-10T05:25:41+00:00
    Is this a Surface specific issue, or is it also related to the Intel power management bug? I'm just curious 🤔
