Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-08-31T05:20:55+00:00
    Didn't work for me. Thanks anyway.
    2019-08-30T09:50:18+00:00
    i have the same issue
    2019-08-29T05:42:53+00:00
    I'm having a similar issue with a Surface Book 2. The battery drain while off is not as drastic, but is something like 2% overnight and will continue to drain while off.
    I took it in since it was only a month old or so to a Microsoft Store and got an exchange. I had run extensive battery reports and sleep studies. I worked with Microsoft Support via twitter too. Nothing helped. I tried the battery driver removal for the tablet portion but that did not work.
    I got an exchange. The exchange was not brand new. I ran a battery report when I got it to see the tablet portion had 30 something cycles while the base had none. However, it worked fine for a short time. I actually kept a log and never had one issue with the exchange as I got it for the first week + or so. I turned it off and on every night while using another computer. The battery never drained. Then I started with updates and slowly installing a few programs I typically use, which are not complicated. Office, and a few others. Then the drain started. I don't think it's a firmware issue, but a windows update. Who knows really.
    This one is older but shows my case. This is actually worse I think than my brand new Surface Book 2. I think it's overnight drain was 2%.
    2019-08-29T00:00:49+00:00
    No worries :)
