Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-08-28T10:44:56+00:00
    Has anyone here been able to verify that this "fix" works? I haven't had an opportunity lately where it's been convenient to shutdown my PC for 10-12 hours, and frankly, I'd like some confirmation that this works before I even bother to try.
    I can verify that mine was fixed and working normally. Thanks for advice.
    2019-08-28T10:36:14+00:00
    Windows will automatically reinstall the drivers the next time you restart/power on your Surface
    2019-08-28T03:46:48+00:00
    The steps say to uninstall the drivers. At what point do you reinstall them, and how?
    2019-08-26T06:06:27+00:00
    I got confirmations via private message on Reddit.
    Like I said in my original post, do it at night before you go to bed :)
