Surface Pro microSD card unmounts after waking up from sleep
2013-03-01T00:26:48+00:00
I've recently bought Surface Pro along with a 64 GB sd card. I've noticed that after a long sleep period, the SD card unmounts itself and I can no longer find it under explorer. I need to remove and reinsert it before Windows detects the card again. This doesn't happen if I wake up the device shortly after putting it to sleep, only after a few hours. I wouldn't mind it as much if I didn't have to set up Skydrive again after reinserting. I think it might have something to do with s3 sleep, and might be a driver/software error, but I'm not entirely sure. Any ideas?
2014-07-22T16:48:29+00:00
I finally solved this problem by enabled write-caching for the SD card.  My card no longer unmounts unexpectedly when changing power modes.  I realize this comes with some risk of possible data loss if the card is not ejected properly.
  1. I right-clicked on the SD card device in device manager under Disk Drives.
  2. Then clicked properties
  3. Then went to the policies tab
  4. And then selected "best performance"
So far, no unexpected dismounts and no data corruption.  This has also improved the performance of the device as reads and writes of large files seem to be much smoother now.
My theory is that this setting is preventing the slot from powering down while in a hibernated or suspended state.
2014-02-06T04:56:51+00:00
Hello Ted
Check out my other post here
http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfdevice/micro-sd-slot-no-longer-recognized-in-the-surface/2705d99f-440a-41a4-9bdf-965f1b092efd
Eventually I changed the card same make/ model, formatted it as NTFS and so far have had no issues at all...........and its been almost 2 months now.
I think Scandisk have issues with quality control ?
Try a full format on NTFS , it does take sometime
If it still has issues after that I would use the card in your phone or something else and by another one brand new for the slate.
It worked for me.
I guess we will get the same issues when the 128GB MSD card comes out!
Good luck
2015-07-17T20:46:00+00:00
Simply change the driver to generic USB mass storage.
78 additional answers
    2013-11-20T07:32:03+00:00
    has anyone found a fix for this yet?  I just got a 64gb card for my pro (windows 8.1) and its exhibiting this dismount behavior.  I am trying to use it to store some programs (Office and Lightroom) so having this issue is frustrating to say the least as I am suddenly unable to access these applications.
    Microsoft, in billing the expandable storage ability of these devices, has failed to address some serious issues in it's useability.  I don't enjoy paying to be a beta tester.
    2013-06-21T19:24:45+00:00
    Don't know if this has been fixed or anything. Mine is still doing it. It happens quite frequently whenever I change my scaling ("Make text and other items larger or smaller") for playing games.
    I have the SanDisk Ultra 64 GB MicroSDXC Class 10 UHS-1 card: http://www.amazon.com/gp/product/B009QZH6JS/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1 and it is formatted to exFat.
    Please let me know something is somebody has found a working solution. Or do we know that it is the SanDisk card itself? It seems that most people here have been using that card.
