Surface Pro microSD card unmounts after waking up from sleep
2013-03-01T00:26:48+00:00
I've recently bought Surface Pro along with a 64 GB sd card. I've noticed that after a long sleep period, the SD card unmounts itself and I can no longer find it under explorer. I need to remove and reinsert it before Windows detects the card again. This doesn't happen if I wake up the device shortly after putting it to sleep, only after a few hours. I wouldn't mind it as much if I didn't have to set up Skydrive again after reinserting. I think it might have something to do with s3 sleep, and might be a driver/software error, but I'm not entirely sure. Any ideas?
2014-07-22T16:48:29+00:00
I finally solved this problem by enabled write-caching for the SD card.  My card no longer unmounts unexpectedly when changing power modes.  I realize this comes with some risk of possible data loss if the card is not ejected properly.
  1. I right-clicked on the SD card device in device manager under Disk Drives.
  2. Then clicked properties
  3. Then went to the policies tab
  4. And then selected "best performance"
So far, no unexpected dismounts and no data corruption.  This has also improved the performance of the device as reads and writes of large files seem to be much smoother now.
My theory is that this setting is preventing the slot from powering down while in a hibernated or suspended state.
2014-02-06T04:56:51+00:00
Hello Ted
Check out my other post here
http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfdevice/micro-sd-slot-no-longer-recognized-in-the-surface/2705d99f-440a-41a4-9bdf-965f1b092efd
Eventually I changed the card same make/ model, formatted it as NTFS and so far have had no issues at all...........and its been almost 2 months now.
I think Scandisk have issues with quality control ?
Try a full format on NTFS , it does take sometime
If it still has issues after that I would use the card in your phone or something else and by another one brand new for the slate.
It worked for me.
I guess we will get the same issues when the 128GB MSD card comes out!
Good luck
2015-07-17T20:46:00+00:00
Simply change the driver to generic USB mass storage.
78 additional answers
    2013-06-13T01:39:54+00:00
    Same Problem. My "SanDisk Ultra microSDXC 64GB Class 10" dismounts after the Surface Pro went to sleep. I have to reinsert the Card for it to be available again.
    It´s formatted with NTFS and encrypted with BitLocker.
    Altough I´ll try the workaround with the VHD this seems to be a bug that Microsoft should fix.
    Same problem also same SD card. But mine is ExFat. So using NTFS doesn't solve the problem? Where is the admin?
    Yep.
    Formatting to NTFS did not help. I have also mount the NTFS into a virtual drive and the same phenomenon appears. The virtual "icon" is still present into the directory but the link behind is empty.
    We are all facing issue with Sandisk 64 Go or anyone else has tried with other brand?
    Any reply from admin?
    Another way to mount it again is to use the power button ==> sleep and awake.
    2013-06-09T04:13:06+00:00
