Surface Pro 4 Bulging Battery / Screen. 3 1/2 years old.
2019-06-30T14:34:09+00:00
So, like many others on this forum, we have a Surface Pro 4, in which the battery has decided to self-destruct, destroying a £1,700 machine.
The screen hasn't popped off, but the battery has swollen enough to prevent the hinge from opening as it should and for the glass on the front to be very distorted, and it registers random screen input, all the while running hotter than the central heating.
I've spoken to support. They unhelpfully told me that because my warranty is up, I would have to pay several hundred pounds (£333) to replace the machine with a refurbished unit. To me, this is completely unacceptable. These devices are clearly flawed by design. This issue is too wide spread for it to be a coincidence. The batteries used in these devices are obviously flawed, and when I suggested as such, Sean L, the person dealing with my case, stopped responding (A few days after that, I wrote to Microsoft's twitter support who confirmed that the case had been closed. Thanks Sean L.)
If the device is dangerous (as suggested by the agent who I spoke to on the phone in the first instance) and it does catch fire while we are away this summer, and it subsequently burns down a multi-million pound Cambridge University building? What then, Microsoft? You'll wish you'd just replaced it then, won't you.
  1. Deleted
    2021-10-12T22:07:40+00:00
    i'm interested. sent you a mail. hope it arrives
    2021-10-12T22:06:10+00:00
    Just had the same problem. First i had some yellow area's on the side of the screen. didn't notice the bulging immediately but a few says later the screen popped off on one side.
    I called support and though initially they suggested they would replace it once they confirmed it was a faulty battery, they are now saying the Surface Pro 4 was discontinued as of last month and there is nothing they can do.
    Like everyone else on this thread i find this appalling. Has anyone been provided a suitable solution yet?
    I've email Blake to see if i can join the collective action.
    Regards,
    Sahan
    2021-09-20T21:59:53+00:00
    I posted a similar question, but the thread was locked. The answer given by the agent was to stop using the device and contact support, but when I contacted support previously they were unable to help and I am not able to stop using the device. I posted my question to get advice from others that have been put into the same predicament as myself, but now I am in some sort of support loop.
    My thread: https://answers.microsoft.com/en-us/surface/forum/all/surface-pro-4-swollen-battery-safety-and-options/790a5153-7de9-479a-af3c-2ef956195868
    2021-09-15T17:25:43+00:00
    I have two surface pro 4's that have screen warpages issues that may be caused by a bulging battery. What are my options?
