Yep same with me. The tech told me " we extended the warranty for 3 years" since it has been 3 years past the date and the SP4 is no longer produced you can buy a SP5 for $ 600. Unbelievable, i am done with microsoft. i will never buy another one of their machines.
Surface Pro 4 Bulging Battery / Screen. 3 1/2 years old.
So, like many others on this forum, we have a Surface Pro 4, in which the battery has decided to self-destruct, destroying a £1,700 machine.
The screen hasn't popped off, but the battery has swollen enough to prevent the hinge from opening as it should and for the glass on the front to be very distorted, and it registers random screen input, all the while running hotter than the central heating.
I've spoken to support. They unhelpfully told me that because my warranty is up, I would have to pay several hundred pounds (£333) to replace the machine with a refurbished unit. To me, this is completely unacceptable. These devices are clearly flawed by design. This issue is too wide spread for it to be a coincidence. The batteries used in these devices are obviously flawed, and when I suggested as such, Sean L, the person dealing with my case, stopped responding (A few days after that, I wrote to Microsoft's twitter support who confirmed that the case had been closed. Thanks Sean L.)
If the device is dangerous (as suggested by the agent who I spoke to on the phone in the first instance) and it does catch fire while we are away this summer, and it subsequently burns down a multi-million pound Cambridge University building? What then, Microsoft? You'll wish you'd just replaced it then, won't you.
Deleted
2020-12-28T21:35:49+00:00 -
2020-11-28T21:58:38+00:00 Just the same two weeks back and forth and then an offer of a 450 dollar refurb. Not what you expect from spending almost 2000 dollars a few years ago. I shall never buy microsoft again. On Black Friday ordered a new Dell XPS13 which doesn't have a dangerous battery issue and should give me years of service.
2020-11-16T02:17:21+00:00 same issue present, issue likely present for a while but as the machine is stationary on desk plugged into hub only noticed the issue this week. Called support as its just outsidr of the 3 years they will not help and want to charge $1,000 for a replacement (can get a Mac for $250 more)
have a Mac on my desk thats still working after 6 years no issues.
more should be done to support this is terrible ans a clear manufacturers fault. Ask support to escalate the issue for a potential overide with how close it is to the 3 years would not help or entertain an escalation ans repeated its not a known issue.
Deleted
