I also have the same issue with a newly bought (and updated) SL3. When I plug an USB-C to HDMI dongle in, a connection sound plays but it never recognizes the external display. The same dongle/external display works fine with my Surface Go. I've tried different HDMI cables and using an older version of the Iris graphics driver, but the same issue persisted. I hope Intel/Microsoft fixes this issue soon.
Surface Laptop 3 (Intel) issue with DP1.2 monitor after installing January 2020 updates
Just a heads up and if someone from Microsoft sees this maybe talk to the Surface team:
After installing the January 2020 driver and firmware updates for Microsoft Surface Laptop 3 (Intel), my machine detected my external monitor (Dell U2715H) as 640x480.
The connection is made from SL3 -> Lenovo USB-C Dock Gen 2 -> Displayport to Mini Displayport on the Dell U2715h.
The problem went away after I disabled DP1.2 on the Dell Monitor and the screen was detected with its native resolution of 2560x1440 again.
I think this should be added to the known issues on this article if possible: https://support.microsoft.com/en-us/help/4526150/surface-laptop-3-update-history
Surface | Surface Laptop | Display and screen
2020-03-18T17:25:49+00:00 -
2020-03-14T20:27:49+00:00 Hi everyone,
I’ve had similar issues to all of you, more specifically JDBull7. I have a Surface Laptop 3 which i bought some time in October, a week after it came out. Anyway, i just purchased a USB-C to HDMI splitter adaptor as I have an HP 27er display and plan on getting another one. When I plugged in the adaptor, the laptop made a sound as if it recognized something plugged in, and my display would turn on- but no signal. I then went to the system settings to check the display, then hit detect, and windows told me it could not detect the display. After that, I checked “devices”, and ironically it said “HP 27er”, therefore it knew it was connected to a display. I have tried multiple fixing measures, but they have not worked. This is frustrating, and i can’t really believe such an expensive device has such faults.
Barb Bowman 80,810 Reputation points MVP Volunteer Moderator2020-03-02T11:00:00+00:00 If it was me and I really wanted a SL3, I'd return for full refund. Then
repurchase. That would restart the return window clock. Rinse and repeat. -
2020-03-02T07:02:27+00:00 Any updates?? It has been a month that this problem has been reported.
Should I be returning the laptop soon since the return policy is almost up?
2020-02-25T15:15:27+00:00 Your monitors probably don't support 640 x480. My monitor at home does, my two monitors at work don't.
Yes, I have tried that as well and that doesn't work for me either. What Display Adapter do you have? MY Surface Pro 7 has the Intel Iris Plus Graphics and I have tried numerous driver versions. My current driver version is 26.20.100.7641 dated 12/21/2019.
It's strange because whenever I pug in external monitors I hear the sounds like it's connecting but an image never comes up.
