I don't know what happened, but suddenly my Surface Laptop 3 has been fixed. USB C to HDMI/DVI cable. And USB C to HDMI/HDMI.
Surface Laptop 3 (Intel) issue with DP1.2 monitor after installing January 2020 updates
Just a heads up and if someone from Microsoft sees this maybe talk to the Surface team:
After installing the January 2020 driver and firmware updates for Microsoft Surface Laptop 3 (Intel), my machine detected my external monitor (Dell U2715H) as 640x480.
The connection is made from SL3 -> Lenovo USB-C Dock Gen 2 -> Displayport to Mini Displayport on the Dell U2715h.
The problem went away after I disabled DP1.2 on the Dell Monitor and the screen was detected with its native resolution of 2560x1440 again.
I think this should be added to the known issues on this article if possible: https://support.microsoft.com/en-us/help/4526150/surface-laptop-3-update-history
Surface | Surface Laptop | Display and screen
2020-07-11T15:20:19+00:00 -
2020-07-11T10:25:23+00:00 same here got Samsung 49 Monitor.
Resolution only 640*480
Driver 25.20.100.7101 not available.
Surface pro 7 high end version...... Spend 2700 Bucks + 800 Bucks for monitor.
Try all updates but no changes....
2020-07-09T00:20:38+00:00 The USB-C to Display Port 1.4 HBR3 cable fixed the problem.
Intel did come out with 2 additional versions of the Iris Plus Graphics card:
* 27.20.100.8336 <- I tested this one but it failed
* 27.20.100.8425 <- I have not tested this one
My setup:
Surface Laptop 3 with Microsoft docking station (latest firmware)
Windows 10 2004
Samsung LC49RG90SSEXXY
