Surface Pro 7 (i7, 16GB, 512GB) - Battery Life?
2019-11-04T13:14:39+00:00
I picked up a Surface Pro 7 on launch but I'm really struggling with the battery life, with light usage (a few office apps and a few tabs in Edge) I'm struggling to get more than 5 hours, even with Battery Saving mode on, brightness at around 20-25 and nothing running the back ground.
I've updated everything to it latest version, surely I should be seeing better battery life than this?
    2020-08-20T16:52:08+00:00
    Shoot I get 2.5 hours max out of mine and it was sent to me "new" after I purchased one in December that would not work or read any of the surface keyboards so I had to send it in to Microsoft to replace. Now my kids started school; virtually and it wont last. My 10 year old mac lasts for days on sleep and will run all day without needing to charge yet this new pro 7 will not.
    2020-06-22T02:57:40+00:00
    Hello I was needing help I tried doing everything I believe I did it all right the instuction you put out but I lost 20 percent in just less than an hour
    2019-11-05T17:25:19+00:00
    Hi, we have another work around here. Try to lower down the battery level to 10% then charge up to 100% without using the device. Once done, set the brightness to 50%, do not connect any accessories, unplug the PSU, connect to Wi-FI and watch a High Definition Movie. Let us know how much battery life you will get.
  4. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2019-11-04T22:41:11+00:00
    Paul Thurrott's review is interesting. He is getting 6 hours only. So I doubt that any hoop jumping will change this much. https://www.thurrott.com/mobile/microsoft-surface/221387/microsoft-surface-pro-7-review
    2019-11-04T15:23:23+00:00
    Hello ChrisMitchell9,
    Thank you for reaching out Microsoft Community. Try to follow the instructions below and test your Surface battery life.
    • Run Surface Diagnostic Toolkit. It is a self-healing tool which looks for potential issues and fixes them, as well as ensures your device is completely up to date. Or manually check Windows Updates by going to Settings > Update & Security > Windows Updates > Check for updates.
    • Uninstall and reinstall battery driver. From Device Manager, expand the Batteries category. Right click Microsoft ACPI-Compliant Control Method Battery, select the Driver tab, and select Uninstall > OK. Restart the device.
    • Go to Download drivers and firmware for Surface and download the .msi file. This is to make sure you got the latest Drivers and Firmware.
      • If there's not an .msi file that corresponds to the build of Windows 10 you have installed, select the .msi file that's closest to your build number.
      • To find out which version and build of Windows you're using, select Start > Settings  > System  > About , then look under Windows Specifications to find your operating system version and OS build number.
    Please keep us posted.
    Regards,
    KarenJune_F
