What is "carney"? How did you remove that update? Thanks
Surface Pro 7 (i7, 16GB, 512GB) - Battery Life?
I picked up a Surface Pro 7 on launch but I'm really struggling with the battery life, with light usage (a few office apps and a few tabs in Edge) I'm struggling to get more than 5 hours, even with Battery Saving mode on, brightness at around 20-25 and nothing running the back ground.
I've updated everything to it latest version, surely I should be seeing better battery life than this?
2020-05-10T19:01:02+00:00 -
2020-02-06T21:45:29+00:00 Unfortunately 5.5 hours on Power Saver and minimal cpu activity is 'normal' so there appears to be nothing you can do to improve that until Microsoft acknowledges the problem and provides a fix.
2020-01-06T00:17:13+00:00 On a brand new Surface 7 Pro (i5 16 Gb), at 50% brightness, all updates installed, windows build 1909, I got 5.5 hours with Wi-Fi on, browsing, 1-2 hours of youtube, some coding in ssh terminal. Requested a return... I'll do a few more runs this week before sending it back, but for now it's quite poor battery life.
2019-12-11T02:01:31+00:00 Hi
I've been having same problem - I did a full fresh start reinstall but made no difference. 5.5 hours is maximum I can get using Power Saver mode. Everything I've read online I've found no-one getting better than 5-6 hours.
2019-11-26T06:59:29+00:00 I own an i7 16Gb 512Gb
cannot use around all day
full-load may sustain around 5-6 hours
power save mode improve little
