Microsoft 365 features that help users manage their subscriptions, account settings, and billing information.
I've not yet had to do another import, but on my support ticket they said it was now fixed.
Hello All,
I'm stuck in a very strange problem and need help.
I imported pst file to m365 exchange using lifecycle data management console (https://compliance.microsoft.com), i sent as usal my pst using azcopy; i validate my mapping file and then i launched import to 365, as I maded it several times.
After a long time (my pst are quite little (12 gb in two files) i got an import error.
The same error appears on log with each pst.
Many thanks for helping me.
Best regards.
Herve
Here are the logs :
PST Filename,Target Mailbox,Import Status,Error,Total Items,Item Imported,Target Folder,Skipped Item Count,Last Failure,Total Item Size,Imported Item Size
mypstfilename.pst,___@___.___,Failed,Unknown,0,0,,0,System.NullReferenceException: Object reference not set to an instance of an object.
at Microsoft.IdentityModel.Clients.ActiveDirectory.AuthenticationContext.RunAsyncTaskT
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetAppTokenFromESTS(OAuthTokenType tokenType, String tenantId, String serviceName, String serviceHostName) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 492
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.OAuthHackToInsertServicePrincipal(String tenantId) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 238
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetAppTokenFromAcs(OAuthTokenType tokenType, String tenantId, String serviceName, String serviceHostName) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 463
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.<>c__DisplayClass18_0.<GetTenantToken>b__0(String serviceName) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 198
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetAuthToken(OAuthTokenType tokenType, String tenantId, String serviceHostName, Func`2 authentication) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 367
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetUserToken(OAuthTokenType tokenType, String tenantId, String upn, String puid, String serviceHostName, Boolean usingSts) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 215
at Microsoft.Office.Compliance.Ingestion.PswsOAuthAuthenticator.Authenticate(HttpWebRequest request) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\PswsOAuthAuthenticator.cs:line 106
at Microsoft.Exchange.PswsClient.PswsCmdlet.InternalRun()
at Microsoft.Exchange.PswsClient.NewPswsCmdlet`1.Run()
at Microsoft.Office.Compliance.Ingestion.ExchangeIngestionProvider.CreateNewMailboxImportRequest(String targetId, String azureBlobStorageAccountUri, String azureBlobSASToken, Boolean isArchive, String azureStatusPublishEndpointInfo, String name, String targetRootFolder, Nullable`1 contentCodePage, Int32 unrecognizedMailLimitPercent, String rulesBlobSasUri, ILogWriter logWriter, String& cmdText, String& error) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\IngestionProvider\ExchangeIngestionProvider.cs:line 727,0,0
Are you still having this issue?
Everything looks good on my end with the 365 import service among other things.
I'm also unable to find incident EX450352 anywhere under service health or via Google.
Hi Marcus,
If I run Get-AzureADServicePrincipal -SearchString "Office 365 Import Service" before the change, nothing is returned.
If I then run: Connect-AzureAD
New-AzureADServicePrincipal -AppId 3eb95cef-b10f-46fe-94e0-969a3d4c9292
and then re-run: Get-AzureADServicePrincipal -SearchString "Office 365 Import Service"
It then returns a result, and import works.
Champagne !!!!
I hope they will solve the problem quickly
Usually within 48 hours once globally recognised.
