Stuck in import pst problem
2022-10-21T21:05:37+00:00
Hello All,
I'm stuck in a very strange problem and need help.
I imported pst file to m365 exchange using lifecycle data management console (https://compliance.microsoft.com), i sent as usal my pst using azcopy; i validate my mapping file and then i launched import to 365, as I maded it several times.
After a long time (my pst are quite little (12 gb in two files) i got an import error.
The same error appears on log with each pst.
Many thanks for helping me.
Best regards.
Herve
Here are the logs :
PST Filename,Target Mailbox,Import Status,Error,Total Items,Item Imported,Target Folder,Skipped Item Count,Last Failure,Total Item Size,Imported Item Size
mypstfilename.pst,___@___.___,Failed,Unknown,0,0,,0,System.NullReferenceException: Object reference not set to an instance of an object.
at Microsoft.IdentityModel.Clients.ActiveDirectory.AuthenticationContext.RunAsyncTaskT
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetAppTokenFromESTS(OAuthTokenType tokenType, String tenantId, String serviceName, String serviceHostName) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 492
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.OAuthHackToInsertServicePrincipal(String tenantId) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 238
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetAppTokenFromAcs(OAuthTokenType tokenType, String tenantId, String serviceName, String serviceHostName) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 463
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.<>c__DisplayClass18_0.<GetTenantToken>b__0(String serviceName) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 198
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetAuthToken(OAuthTokenType tokenType, String tenantId, String serviceHostName, Func`2 authentication) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 367
at Microsoft.Office.Compliance.Ingestion.OAuthProvider.GetUserToken(OAuthTokenType tokenType, String tenantId, String upn, String puid, String serviceHostName, Boolean usingSts) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\OAuthProvider.cs:line 215
at Microsoft.Office.Compliance.Ingestion.PswsOAuthAuthenticator.Authenticate(HttpWebRequest request) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\PSWSProvider\PswsOAuthAuthenticator.cs:line 106
at Microsoft.Exchange.PswsClient.PswsCmdlet.InternalRun()
at Microsoft.Exchange.PswsClient.NewPswsCmdlet`1.Run()
at Microsoft.Office.Compliance.Ingestion.ExchangeIngestionProvider.CreateNewMailboxImportRequest(String targetId, String azureBlobStorageAccountUri, String azureBlobSASToken, Boolean isArchive, String azureStatusPublishEndpointInfo, String name, String targetRootFolder, Nullable`1 contentCodePage, Int32 unrecognizedMailLimitPercent, String rulesBlobSasUri, ILogWriter logWriter, String& cmdText, String& error) in k:\dbs\sh\nibr\1018_000434\cmd\0\sources\dev\ingestion\src\workloadapi\IngestionProvider\ExchangeIngestionProvider.cs:line 727,0,0
Microsoft 365 and Office | Subscription, account, billing | For business | Other
2022-11-17T07:29:59+00:00
I've not yet had to do another import, but on my support ticket they said it was now fixed.
2022-11-10T16:42:09+00:00
Are you still having this issue?
Everything looks good on my end with the 365 import service among other things.
I'm also unable to find incident EX450352 anywhere under service health or via Google.
50 additional answers
    2022-11-01T10:30:04+00:00
    I don't believe the issue has actually been resolved yet. I don't even think the reference has been added to the admin dashboard. Hopefully they'll add it for us all to see soon. For now I would just do manual imports for small clients.
    2022-10-31T18:39:53+00:00
    Nope still failing with
    2022-10-31T14:11:32+00:00
    Any luck with the import, I m facing the same issue here. I have tried several times till now.
