A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
For me it worked after entering insider program and updating.
I am using Excel 2016 on Windows 10. Today, the "Insert comment" option disappeared from the right-click pop-up context menu. When I right-click on a cell with no comment, there is no option to add one. If I right-click on a cell with a comment, I can edit or delete the comment. On the Insert tab of the ribbon, the Comments section is grayed out. This problem is affecting all spreadsheets that I have tried.
I googled the problem and tried every solution offered but none of them worked. How can I add comments to cells again?
Thank you
My insert comment option is missing
It works now.
Suddenly I have two new options in the right click menu (new comment and new note).
The thing that works like the old insert comment is new note.
I don't know if it help anyone but I changed the Account > Office Insider level to Insider.
Good luck.
Thanks! This morning I suddenly have "Insert Comment" as an option when I right-click. Yay!!!
I don't have a "new note" option, but that's okay, now that the insert comment is back. How weird is all this.
I have had a lot of experience with programmers"tweaking" things, and the one step they usually miss is testing and probably even more importantly, is asking a non-techie user if everything works!!!!
Thanks again.
Obviously this is only working for certain people. as I still have to use Shift + F2.
I have the same issue. Shift+f2 will insert a comment, but the option is now missing from the right click menu.
It works now.
Good luck.
Thanks again.
