Insert Comment option is missing from right-click menu
2019-03-09T21:28:27+00:00
I am using Excel 2016 on Windows 10. Today, the "Insert comment" option disappeared from the right-click pop-up context menu. When I right-click on a cell with no comment, there is no option to add one. If I right-click on a cell with a comment, I can edit or delete the comment. On the Insert tab of the ribbon, the Comments section is grayed out. This problem is affecting all spreadsheets that I have tried.
I googled the problem and tried every solution offered but none of them worked. How can I add comments to cells again?
Thank you
    2021-01-04T15:41:59+00:00
    Shift +F2 doesn't work for my 2019 Microsoft.   Super frustrating to not have a consistent way for a work around.   I've been using MS Office for 15 years+ and the no comment option started happening about 2 months ago.  Super frustrating.  as I'm an avid user of tables and comments.
