Insert Comment option is missing from right-click menu
2019-03-09T21:28:27+00:00
I am using Excel 2016 on Windows 10. Today, the "Insert comment" option disappeared from the right-click pop-up context menu. When I right-click on a cell with no comment, there is no option to add one. If I right-click on a cell with a comment, I can edit or delete the comment. On the Insert tab of the ribbon, the Comments section is grayed out. This problem is affecting all spreadsheets that I have tried.
I googled the problem and tried every solution offered but none of them worked. How can I add comments to cells again?
Thank you
    2020-02-19T22:26:55+00:00
    I posted a few days ago that the Insert Comment feature/option while R click in Excel on a cell disappeared, it's active again today and no need for the workaround(s) anymore.
    Only change between my post a few days ago (with the problem) and today (without the problem) is that I had Shut Down my computer at one point, although I'm not exactly sure when the Insert Comment upon R click re activated.
    2020-02-19T15:07:37+00:00
    the insert comment option has disappeared from my right click context menu too.  Running Excel Office 365.   If I use one of the work arounds suggested above to insert a comment, the option then appears to edit or delete the comment.
    But if the cell has no comment in it, I have to use 3 or 4 steps to insert it as opposed to one previously.... hoping this is a temporary bug because it stupid.
    This thread started almost a year ago, so I guess it depends on your definition of temporary.  To be fair, how long do those 3 or 4 steps actually take? Bigger picture, worse things happening around the world and all that.
    2020-02-19T14:29:47+00:00
    2020-02-18T13:38:06+00:00
    Home tab, click "Tell me what you want to do" type insert comment. Be sure you are in the cell where u want the comment.
    Worked for me!
    2020-02-08T16:10:33+00:00
    Shift + f2 works
    Would like to know how to add the feature back (upon R click) - seems like a lot of people are having problems with the Insert Comment disappearing (was working fine for me the other day).
