I found this thread while researching Insert Comment option missing from right-click menu and Comments section grayed out on the Review ribbon.
Here is what I found and the fix.
- The missing Insert Comment/New Comment on the right click menu and the grayed out Comments section of the Review Ribbon appears to only affect files that are older Excel 97-2003 (.xls) format. These are files that have shown in Compatibility Mode since
Excel 2007.
- In Excel 2016/Office 365 there are now both Comments and Noteson the Review tab:
- Comments in Excel 2016/Office 365 are more like a discussion thread in the right panel.
- Notes in Excel 2016/Office 365 look identical to what Comments looked like in older versions of Excel. If there were existing comments in a workbook created in older version of Excel (both .xls and .xlsx files), they will now appear as
Notes.
- You have to select Show Comments and Show All Notes if you are using both and want to see them all. If Show All Notes was already selected, you need to IT Crowd it by turning it off and back on to see previous items that had been Comments but are now Notes.
- The Shift+F2 option mentioned above inserts a New Note, not a Comment.
- Running Office Updates did not work.
- Saving As modern .xlsx format did not work.
- Going to File > Info and clicking on Convert next to Compatibility Mode forces you to save as .xlsx file. This
DID work and now Comments section is no longer grayed out on the Review ribbon and New Comment now shows up in the right-click menu.
I am not going to editorialize on why MS decided to change what was called Comments and now call them Notes. I am going to editorialize on the decision to create a brand new feature and call it the exact same thing as a feature that people have used for
decades:
Thanks a lot, that was an awesome decision.
I'm sure there were plenty of folks in those meetings who argued against this. I would love to hear the comments that supported this choice.
