Office 365 cloud features do not work when using a privacy VPN
2016-07-27T20:31:21+00:00
When I have a privacy VPN active (such as Private Internet Access - PIA) I can't access the cloud features on Office 365 (such as online templates, OneNote sync to the cloud, Excel or Word saving to OneDrive directly, etc). I have tried 3 different VPN solutions: PIA, NordVPN and VPNArea and they all exhibit the same issue. Is there a way to solve this or to tell Office to bypass the VPN?
    2018-08-31T13:26:31+00:00
    I have struggled with this problem for some time (i.e., NordVPN NOT playing nice with Office 365 connected applications) and this solution -- adding my gateway as the default gateway in the Tap-NordVPN Ethernet adapter - per Mac Wheeler's post -- is the only thing that worked.  Once I did that -- everything worked fine, AND, the connection appeared much more stable and faster.  So, I'm wondering if this is something that should  done with NordVPN even if you're not using Office 365.
    THANK YOU TO Mac Wheeler and all the rest of you contributors who have tried to solve this problem.  Maddening!
    2018-08-31T10:08:37+00:00
    Arrrgh, I have had this problem for months.
    I have tried everything, but it didn't work.
    I have found the correct solution that should work for everyone and it is here: https://www.macwheeler.com/windows-10-office-365-cannot-connect-over-openvpn-fixed/
    It comes down to setting a default gateway to your Tap connection so that the Network Location Awareness (NLA) and the Network Connection Status Indicator (NCSI) can discern whether an active network connection is available.
    Sigh...
    2018-08-24T23:09:12+00:00
    Nope, switched to Dropbox and now no issues.
    2018-08-19T04:53:46+00:00
    After coming back to PIA after not using any VPN for a year, I noticed the same problems that the OP and many others were having.  I changed from UDP to TCP.  Excel wanted me to sign into Office 365 again.   One Note 2016 wanted me to sign in again also.  It's only been 30 minutes but everything is working well so far.
    It didn't work for me (with NordVPN), but hopefully it will work for you.  The only thing that has worked for me has been to add my gateway as the default gateway in the Tap-NordVPN Ethernet adapter - per Mac Wheeler's post.  It still passes the tests at IPLeak.net so hopefully it works AND I'm still protected by the VPN.
    Paul
    2018-08-18T20:12:18+00:00
