A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
Hi Monti
Do you see the ink disappearing at the same frequency as before?
To make sure that the installation itself didn't fail, could you try the following:
- Go to either one of the following folders. The path will depend on your device
C:\Program Files\Microsoft Office\root\Office16\
or
C:\Program Files (x86)\Microsoft Office\root\Office16\
- Find onmain.dll within the folder
- Right click and select properties
- Go to the Details tab
5. Copy here the File version and Product version numbers listed.
The latest update contains a fix for a case where we know ink will disappear that matches the description given on this forum. We have tested, verified and validated that change. There can be different bugs that leads to the ink disappearing on OneNote. If you and others are still hitting the bug even with the update, then there is possibly a different cause for that specific ink disappearing bug and we will investigate it.
Mavis
