Processes in Microsoft 365 for setting up Office apps, redeeming product keys, and activating licenses.
David, I have the same issue.
However, when I try to download and run the hotfix, I get a notification saying I don't have the product installed on my machine.
I have Office 2013 w/ Publisher 2013 (Professional) installed. I have the 64-bit version and downloaded and tried to install.
The previous poster was using Office 365 to access Publisher. Today when I review the hotfix I see that Office 365 is not listed as one of the supported products: https://support.microsoft.com/kb/2760434?wa=wsignin1.0#appliesto
However it sounds like you are using Office Professional 2013 so it should apply. I don't have a good answer as to why the hotfix did not apply.
I followed the link to Technet blog http://blogs.technet.com/b/office_sustained_engineering/archive/2013/09/11/outlook-folder-pane-disappears-after-installing-september-2013-public-update.aspx looking for more information and found this suggestion:
"When you encounter trouble with a Public Update, you can always contact us at http://support.microsoft.com. You can call Microsoft directly at 1-866-234-6020"
While that page is talking about another related patch perhaps you could call and ask MS why KB2760434 does not work, and/or for any other fix for the 'pdf problem". If you get any relevant information, please post back.
Sorry that I don't have a better suggestion.
DavidF
