Comment balloons will not print. WORD 2010
2011-10-25T22:05:21+00:00
Comment balloons will not print.  I have a document that has insertions and deletiions in the text and comments in balloons in the right margin.  When I try to print it, the space is there in the right hand marginto accomidate the ballons but the balloons don't print.  They show up in the Word Print Preview.
2014-01-15T14:08:17+00:00
This is a very old thread, but i'll post here as it's the top Google answer for 'word comments not printing.' I had this problem with a couple of users and i found the problem was that if a document is displayed in the Windows Explorer preview pane comments balloons won't print. With the preview pane disabled (or if you open the document from within Word, as others suggested), it will work.
If it has been opened in the preview pane you need to open task manager and kill winword.exe if it is running in order for it to work.
2012-05-17T17:55:05+00:00
Here's what works for me.  It is still annoying, but at least I can get the comments to print in the shaded area on the paper to match the print preview.  This works for me for printing to PDF, to a networked HP, and to a networked Xerox Mobile Express driver.  I hope it works for you, too.
  1. Close Word.
  2. Re-open Word.
  3. Using Word (not Windows Explorer), open the document.
  4. Print your file.  On the Print page, under Settings, click the button that holds the options like "Print all pages" and make sure that the "Print mark-up" is checked.
I've started doing a test run by printing 1 page to the printer "Adobe PDF", so I know the comment balloons are really printing. This keeps me from wasting paper and pricey color toner, and saves the interruption of a jog down the hall to the network printer.  Once I know the balloons are visible in the PDF, then I send the whole document to print on the network printer.
119 additional answers
    2014-06-25T17:39:33+00:00
    I too tried them all, and the ONLY thing that worked for me was to turn OFF background printing.
    Thank you for your help Nreuben!
    2014-06-04T08:42:41+00:00
    1. Close Word.
    2. Re-open Word.
    The suggestion works but is this issue already fixed with any patch updates?
    2014-05-14T17:10:36+00:00
    I had a eureka and it worked!!!
    I had the same issue of trying to print comments to no avail.  Here's what unlocked the problem:
    Track changes-- change tracking options - - under balloons choose always or when you want them
    On tracking -- Final: Show Markup  ORShow Markup
    On print- - settings - - Print markup
    My whole problem was somehow balloons was set at never.
    hope this helps other folks
