PowerPoint found a problem with content in xxxx.ppt__PowerPoint can attempt to repair the presentation.__If you trust the source of this presentation, click repair.__There was an error access the file xxxxx.ppt
2010-12-08T00:39:25+00:00
Problem with Office-2010 PowerPoint-2010
I am trying to download a powerpoint file from a web tool. After downloading when I try to open the file I get the blah blah "PowerPoint can attempt to repair the presentation." When I clicked repair it gave another error message that "There was an error access the file".
After a lot of looking around I HAVE FOUND THE SOLUTION. The "Protected View" settings in PowerPoint has to be changed to be able to consider the web downloaded presentations as safe and viewable. Here is how I did it:
  1. Open PowerPoint 2010 -> Click on File -> Options
  2. On the side tab click on "Trust Center" -> Now click on "Trust Center Settings" which is in the right window.
  3. It opens a new window "Trust Center"
  4. Click on "Protected View" on the left side panel.
  5. Uncheck "Enable protected view for files originating from the internet". - Click OK and OK
This should get rid of "repair my ____" error and open the ppt file.
2011-02-20T18:48:22+00:00
Hi
Although this does solve your problem, it is unsafe to disable the Protected View setting.
It was specifically added to enhance security of opening Office documents from untrusted sources.
If you go to file properties of the file, you may see a button called "Unlock". Unlocking the file should also suffice.
Dr Nitin Paranjape, Office System MVP, Business Efficiency Enhancement Specialist.
66 additional answers
    2015-09-01T02:05:47+00:00
    I made an account just to tell you I love you, thank you
    2012-05-12T15:59:15+00:00
    Awesome!!!, thanks for the solution!!!
    2012-04-18T20:08:56+00:00
    HI there,
    just wanted to say thank you for taking the time to share how you went about fixing this, it had me worried that there were bigger and bader things going on with all my files... im in college and every single lecture note i have is in power point !
    as to what triggered this im not sure but my avast security centre desided it was an illegal copy?? which its not  ?? but shortly after many other things went hay wire? the drivers for my mouse pad being one
    anyway
    thanks again
    2011-05-23T16:11:20+00:00
    This latter solution posted on May 19 didn't work for me. Not sure if it is because I am using a trial version of Office 2010, but don't want to pay to upgrade to full version until I resolve this problem.
    I run Windows Vista 32-bit and have also tried the other workarounds involving unblocking files individually by right clicking on them and selecting unblock button in general tab, and the changing the Trust Center settings as indicated above. Still no joy.
    Any help would be most welcome.
