PowerPoint found a problem with content in xxxx.ppt__PowerPoint can attempt to repair the presentation.__If you trust the source of this presentation, click repair.__There was an error access the file xxxxx.ppt
2010-12-08T00:39:25+00:00
Problem with Office-2010 PowerPoint-2010
I am trying to download a powerpoint file from a web tool. After downloading when I try to open the file I get the blah blah "PowerPoint can attempt to repair the presentation." When I clicked repair it gave another error message that "There was an error access the file".
After a lot of looking around I HAVE FOUND THE SOLUTION. The "Protected View" settings in PowerPoint has to be changed to be able to consider the web downloaded presentations as safe and viewable. Here is how I did it:
  1. Open PowerPoint 2010 -> Click on File -> Options
  2. On the side tab click on "Trust Center" -> Now click on "Trust Center Settings" which is in the right window.
  3. It opens a new window "Trust Center"
  4. Click on "Protected View" on the left side panel.
  5. Uncheck "Enable protected view for files originating from the internet". - Click OK and OK
This should get rid of "repair my ____" error and open the ppt file.
2011-02-20T18:48:22+00:00
Hi
Although this does solve your problem, it is unsafe to disable the Protected View setting.
It was specifically added to enhance security of opening Office documents from untrusted sources.
If you go to file properties of the file, you may see a button called "Unlock". Unlocking the file should also suffice.
Dr Nitin Paranjape, Office System MVP, Business Efficiency Enhancement Specialist.
66 additional answers
    2011-08-04T15:11:27+00:00
    The above "Resolution" did not work for me or for anyone else based on what I've seen on line.
    This solution worked for me:
    In Power Point:
    File > Options > Trust Center > Trust Center Settings...(button) > Trusted Locations > Add New Location...(button) > in the path field I entered:
    C:\
    (or whatever your hard drive letter is)
    and checked the box for 'Subfolders of this location are also trusted"
    2011-05-19T14:47:04+00:00
    Here is the correct solution to the problem:
    Cause
    DCOM security settings do not allow the temporary file structure that must be created.
    Solution
    Set component security settings back to the defaults:
    1. Open Control Panel
    2. Open Administrative Tools
    3. Open Component Services and expand the tree under Console Root to Computers --> My Computer.
    4. Right-click on My Computer and select Properties.
    5. Select the Default Properties tab and set the following values:
    ·          Default Authentication Level: Connect
    ·          Default Impersonation Level: Identify
    Please see :http://support.microsoft.com/kb/2387587/en-gb
    2012-08-22T23:59:33+00:00
    Thank you!!!!!!!  This was frustrating me beyond belief.  Able to open ppx documents now.
    2011-03-28T19:52:36+00:00
    If the enhance security caused only trouble, what should we do with it?
