PowerPoint found a problem with content in xxxx.ppt__PowerPoint can attempt to repair the presentation.__If you trust the source of this presentation, click repair.__There was an error access the file xxxxx.ppt
2010-12-08T00:39:25+00:00
Problem with Office-2010 PowerPoint-2010
I am trying to download a powerpoint file from a web tool. After downloading when I try to open the file I get the blah blah "PowerPoint can attempt to repair the presentation." When I clicked repair it gave another error message that "There was an error access the file".
After a lot of looking around I HAVE FOUND THE SOLUTION. The "Protected View" settings in PowerPoint has to be changed to be able to consider the web downloaded presentations as safe and viewable. Here is how I did it:
  1. Open PowerPoint 2010 -> Click on File -> Options
  2. On the side tab click on "Trust Center" -> Now click on "Trust Center Settings" which is in the right window.
  3. It opens a new window "Trust Center"
  4. Click on "Protected View" on the left side panel.
  5. Uncheck "Enable protected view for files originating from the internet". - Click OK and OK
This should get rid of "repair my ____" error and open the ppt file.
2011-02-20T18:48:22+00:00
Hi
Although this does solve your problem, it is unsafe to disable the Protected View setting.
It was specifically added to enhance security of opening Office documents from untrusted sources.
If you go to file properties of the file, you may see a button called "Unlock". Unlocking the file should also suffice.
Dr Nitin Paranjape, Office System MVP, Business Efficiency Enhancement Specialist.
66 additional answers
    2017-08-10T01:50:50+00:00
    hi. I couldnt find ( unblock ) button. Can u tell me what to do.. pleas i need help
    2017-08-03T16:38:59+00:00
    I had also the same Problem, tried above mention solution, problem Resolved. Thanks a lot
    2017-06-27T18:43:28+00:00
    On my particular files there is no UNLOCK option in properties.  Any other suggestions.
    2017-05-16T11:42:32+00:00
    i got the same error message, but could not see the option of Unlock in the file, can you please help me with the that, assist me with reason behind that error message, I mean why this error appear?
