A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
I have tried turning off Aero by choosing a High Contrast theme. It did not solve the problem. I also checked the boxes on the Compatibility Tab to disable desktop composition and to disable visual themes. This did not solve the problem, either. I have tried changing the screen resolutions. This, too, failed.
It seems clear to me that the problem is not with my system (which runs every other Microsoft product, including Word 2007 without problems). It is not with Adobe fonts or Linotype fonts or any other company. The problem is that Microsoft has released a version of Word that simply does not render OpenType fonts with Postcripts outlines properly. They deny this in spite of the overwhelming evidence. Their technicians have seen it. They know people are complaining about it. Alas, there seems to be inadequate motivation for them actually to fix the problem.
I am reminded of the adage in substance abuse programs: the first step in recovery is to admit you have a problem. Microsoft has yet to take the first step to recovery. Perhaps the rest of us should go to an Alanon meeting.
