A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
I have found this web site: http://support.microsoft.com/kb/2121313 Which could answer some of the problems. The other problems are probably based on printers and drivers. This has been a problem even back with MS Office 2000 and before and after. Not all printer drivers support the fonts so therefore they will not list as usable fonts.
Ed
Hey, I'm a lawyer in Texas and I rely on Openface Fonts to set up my legal documents so they look typeset. I did not have any problem in Office 2007, but this sure is making my life miserable.
Of course, all of the fonts . . . Stemple Garamond; Adobe Garamond, Myriad, etc., display perfectly in every other piece of software I use. For it not to work in Office 2010 is just unacceptable. Overall, I really like the product but this is creating headaches (literally and figuratively) when I am trying to proofread documents I have edited several times to submit for Court filings.
