A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
I've had this issue for awhile, and keep waiting for a patch to fix it.
To get around it, immediately after I open the file (which then displays the weird fonts), I select all (ctrl-a), change the font to something else (Time New Roman), and then undo (ctrl-z). Voila, my fonts appear properly.
It only happens on Word 2010. Word 2007 does not manifest these issues.
HTH
I have been having this problem for some time with Word 2010 (Win7 64bit), and have just discovered this forum. I hope the following info may help someone at MS to replicate (and fix) the problem.
The problem for me appears to be an inability to consistently display linked (paragraph and character) styles (in my case user-defined styles 'bold' - defined as Font: Bold; Style: Linked, Quick Style; Based on: Normal; Following style: Normal and ‘bold italic’ - defined as Font: Bold; Italic; Style: Linked, Quick Style; Based on: Normal) that use an OTF font (in my case Helvetica LT Std Cond) when at least one of the styles is applied both to entire paragraphs and individual words within paragraphs at the same time. One style displays correctly and the other doesn’t (it usually initially appears more like Helvetica LT Std, i.e. not the condensed variant). Usually editing and saving the document switches between the two, but you have to scroll up and down to 'redraw' the page to see the change.
The issue has become a major problem for me and I am frustrated that it has not been fixed given the cost of the software. It seems the more I edit the document the bigger the problem becomes with character widths and spacing between them increasing and decreasing - first an annoyance as spacing between characters becomes so great that it is hard to distinguish between spacing between characters and words, making it difficult to read, and also pushing text off the displayable area of the page. I have even had character spacing becoming so tight that the characters overlap and become illegible (whole paragraphs of 5-6 lines condensed to one line) necessitating closing and reopening. (Notes: 1) these problems do not seem to be an issue or affect the saved document file when people with other versions of Word open them; 2) the problems occur regardless of whether or not I save as a Word 2010 (docx or docm) with or without compatibility mode or as Word 1997-2003 (doc))
Further info as requested by moderate:
Printers: Brother HL-5370DW series (default); Epson TX600FW; Fax; PDFCreator
Language: English (New Zealand)
Changing printer does not alter anything
Problem persists regardless of view (Print layout (with or without 'white spaces hidden') Draft, Full screen reading, Outline, etc)
I don’t have earlier versions of Windows I can check on, and it was never a problem when I was using Word 2003 (I never used Word 2007)
