A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
This seems to be the root of the problem for me as well. I have found this bug with many fonts -- not just Adobe's, but those from other highly respected, technically-adept font companies. The hypothesis that Word is hiccuping when it meets PostScript outlines seems plausible, as most if not all of the fonts included with Windows and Office are delivered as TrueType. Most professional fonts produced these days are PostScript-flavored OpenType, so this is a rather serious bug. The no-saving solution isn't ideal in the least, but at least it works for on-screen display. Thanks very much!
Also have this issue with Win7 Office2010 64bit in .docx format (clean document created from scratch), affecting a document with Myriad Pro Family. The Hindi fix about is already implemented but the issue continues. This bug is extremely annoying and since our company font is Myriad Pro - this is preventing deployment of Office 2010 to the organization.
Going to the print screen and changing printer restores the correct view/font. Switching to another window and back to Word 2010 triggers it again. This is not a driver issue.
I have a video of this behaviour.
