Audio not coming through Bluetooth Headset
2023-05-05T14:28:17+00:00
Seemingly randomly, Teams will not output audio through my Bluetooth headset (microphone will consistently work). The only way that I have found to fix it is to restart my computer. This problem is specifically with Teams, system sounds, browser sounds, and Zoom calls will all give audio to the headset, even if teams is not. I am able to see my headset in device settings in Teams and can select it. If I change the audio to output through my laptop speakers, I am able to hear audio.
Some troubleshooting I have tried:
  • Swap around audio devices within Teams
  • Disconnect Headset from laptop
  • Ensure Headset is forgotten from laptop
  • Restart Laptop (This will always fix the issue for an unspecified amount of time
The Bluetooth headset that I am using is Steel Series Artic 9. I can consistently get this headset to work with other Bluetooth devices, such as my personal PC, my wife and my phones, my wife's laptop. So the issue seems to specifically be teams on my work laptop.
Here are 2 examples on when I have seen the issue pop up.
  1. Connected for my first Teams meeting in the morning, audio worked fine. Joined a new meeting 1 hour later and there was no audio. The headset did no disconnect, and was left on until the next meeting.
  2. I put my laptop to sleep when I am not working (been turning it off the past week) when I wake the laptop when I begin work again, the headset will not have audio through teams. This is random as some days it would work and others it would not.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
    2024-07-17T15:38:43+00:00
    A few days ago, I got updates to
    1. Teams - 24165.1414.2987.41.
    2. Dell's docking station
    3. Realtek driver 10.0.246.1
    4. Dell's BIOS
    All at the same time.
    Now, everything works great!
    I'm switching back and forth between different headsets (in the past, sometimes it worked with one specific headset), speakers, docking, and nondocking, and it works!
    Really hope that it won't break again.
    2024-06-21T13:13:58+00:00
    This solution worked for me, except I had to disable and then re-enable it. This got my bluetooth speaker working properly. The microphone on the bluetooth speaker still doesn't work, but the one on my laptop does so that's not a problem for me. (Need the speaker because the laptop speaker is soft.)
    I had the same issue on a HP ZBook Firefly 14" G9, the issue has been fixed via disabling +Intel Smart Sound Technology for Bluetooth Audio+ in Device managerImage
    2023-11-20T17:37:53+00:00
    Thank you. I shall ask my IT Department to disabel that as I don't have access to adjust.
    2023-10-23T06:45:51+00:00
    The following worked for me:
    Check also the apps permission on your phone like camera, microphone and also nearby devices.
    Go to Settings -> Apps -> Teams -> Permissions -> Allow access to "Nearby devices"
    Resource: Can't connect Bluetooth headset to Android Teams https://answers.microsoft.com/en-us/msteams/forum/all/cant-connect-bluetooth-headset-to-android-teams/487f72b3-60ad-435d-a338-5c4d352fd8b1
    2023-10-05T13:57:23+00:00
    I am trying a wired (USB) headset. Our IT dept is trying some out. They are $100 cheaper than the Plantronics Voyager bluetooth one. I'm sure it will work fine!
