Managing sound and video settings during Teams meetings and calls for optimal communication
Same Issue. Bluetooth works perfectly with every other app on my Laptop but not Teams (only after restart). Microsoft please help!
Seemingly randomly, Teams will not output audio through my Bluetooth headset (microphone will consistently work). The only way that I have found to fix it is to restart my computer. This problem is specifically with Teams, system sounds, browser sounds, and Zoom calls will all give audio to the headset, even if teams is not. I am able to see my headset in device settings in Teams and can select it. If I change the audio to output through my laptop speakers, I am able to hear audio.
Some troubleshooting I have tried:
The Bluetooth headset that I am using is Steel Series Artic 9. I can consistently get this headset to work with other Bluetooth devices, such as my personal PC, my wife and my phones, my wife's laptop. So the issue seems to specifically be teams on my work laptop.
Here are 2 examples on when I have seen the issue pop up.
For sound output during Teams I've gone back to wired earbuds plugged into the PC jack socket. Webcam working okay for video and microphone.
Bluetooth earbuds working fine for Zoom sound output and all other apps.
Yes it seems strange. Used Zoom with bluetooth sound and webcam mic + video with no problem yesterday.
Has anyone in MS actually responded?
Dear Jesse,
My name is Alfonzo, an Independent Advisor and I am glad to help you.
It seems like the problem is specific to Teams on your work laptop and not with your Bluetooth headset. Here are some suggestions that may help:
Hopefully, one of these steps will help you fix the problem, so you can use your Bluetooth headset with Teams without having to restart your laptop each time.
If you have any concerns, please let me know.
Best regards,
Alfonzo
