Managing sound and video settings during Teams meetings and calls for optimal communication
Failed again in the first day!. Really annoying ! Hello MS , someone need to chech this....
Hello community,
we are currently rolling out Win 11 (Enterprise 22H2) for our users and more and more are starting to complain about audio problems since the upgrade to Win 11.
For the most part we use Jabra Evolve 65 and 75 headsets, which are certified for Teams (they worked fine with Teams and Win 10).
Reported issues (happening in meetings and calls):
There are no audio issues with other apps like phone app or when watching a video.
We updated audio drivers, updated firmware of the audio devices. Cleared Teams cache, reinstalled Teams, made sure its running the current version. Checked windows audio settings (sometimes people manage to connect the headset via usb dongle and directly to laptops bluetooh at the same time, which can cause problems). We also asked the users to connect their headset with the usb cable instead of the dongle. Nothing helped.
I had one user working with Teams in the browser for a few days and he didnt report any problems there. So maybe its a Teams client issue?
If anyone has an idea for me on how to fix this, I would really appreciate it, since Win 11 rollout is still going on and more and more users will be affected by this. Which I am not looking forward too :)
I am experiencing the same problem after a forced corporate update to Win11, it's worth noting that the audio on my headset works perfectly fine with every other application on the PC, in fact I can even hear the call connect/disconnect tone from Teams through the headset, however Teams will not play the actual audio of voice feedback from other participants nor when doing the Test Call. The issue is directly a Teams problem with Win11, definitely not a driver issue with the headset and the OS.
Similar issue here Jabra Evolve 65 2,97.0 bluetooth or Link 306 2.47.0 on Windows 11 22H2 22621.1848 , Dell Latitude 5430, all drivers upto date. The headset sometimes works and sometimes does not, can go from one teams call to another and it will stop working. Reboot fixes it for a bit. Really frustrating.
Any thoughts, not sure how to trouble shoot this one
With the help of a great friend of mine, if you connect the Jabra device via bluetooth instead of usb, the microphone works.
Curtis
Have the exact same issue with Windows 11 and the Jabra Evolve2 75. It's very frustrating as Windows 10 didn't have this issue, nor did Windows 11 until some recent update.
It's making me appear very unprofessional as a technical director a large multi-national software company.
