Volume too loud in Teams IOS when using AirPods Pro even when set to minimum volume
2020-07-15T03:30:15+00:00
Hi all,
Anyone can propose a fix to a loo loud volume in Teams even when volume is set to minimum?
I’m using AirPods Pro to join Teams’ calls through my iphone and/or ipad. The volume is set to absolutely minimum possible and it’s still a too loud to the point of causing pain if connected for a prolongued time.
It seems to be a Teams’ behaviour as the airpods function well in other apps in the same devices, enabling me to further reduce the volume. For context, the 50% volume of other apps sound like the bare minimum volume of Teams..
Microsoft Teams | Microsoft Teams for business | Teams on mobile devices
    2021-06-28T08:40:28+00:00
    Well it works for me, and I use it most days
    2021-03-26T17:51:33+00:00
    Just go to control centre and turn it down, the volume buttons on the side don’t work
    2021-03-26T17:28:34+00:00
    I am having this problem on iOS too. Teams Volume will not go below 10% and is very loud on Airpods Pro.
    2021-03-12T20:13:13+00:00
    No idea then because it works perfectly fine for me. I’m running AirPod Pros on an iPhone 12 mini.
    2021-03-12T19:00:51+00:00
    I’ve replied to your problem regarding IOS as well. See above
