USB power setting is missing from the Power Options (running Windows 11)
2022-04-03T16:35:44+00:00
I am trying to manage my USB power plan settings but the USB option is missing from the Advanced Power Settings option.
Control Panel/System and Security/Power Options/Edit Plan Settings/Change Advanced Power Settings
FYI:
I am running Windows 11 Home Version 21H2 on an HP Spectre laptop.
I tried some fixes posted for Windows 10, but they did not work.
NOTE: I am trying to change the USB power options to see if this will stop the flickering in my Logi HD 1080p Webcam.
    2023-08-15T10:15:33+00:00
    Hey
    Did you manage to solve it? I also do not see the option and tried all troubleshooting from this post. I do see it in safe mode.
    2023-08-04T17:55:51+00:00
    This doesn't work because there is no usb settings available. It just isn't showing at all. There is no access to these settings in control panel or device manager.
    2023-06-26T09:36:15+00:00
    See this video :- Disable USB Selective Suspend settings in Windows 11 - Bing video
    NO, that is NOT it. because this guy just shows what is NOT there. read the original post before you answer anything!
    2023-02-12T09:51:46+00:00
    I have reported the same problem, but it is not resolved. This continues to have a major impact on my self-publishing business.
    What is the solution?
    Bernard Heys
    theradcliffelad
    2023-01-31T18:38:05+00:00
    No. I found many solutions, but none worked for me. Sorry!
