Hey All,
I was having this same issue and I found this:
https://www.tenforums.com/tutorials/100643-remove-usb-selective-suspend-setting-power-options-windows.html
It worked for me... Hope you all have the same luck as well! :)
Add or Remove "USB selective suspend setting" in Power Options using Command Prompt
1. Open an elevated command prompt.
2. Type the command below you want to use into the elevated command prompt, and press Enter.
(Add - default)
REG ADD HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\2a737441-1930-4402-8d77-b2bebba308a3\48e6b7a6-50f5-4782-a5d4-53bb8f07e226 /v Attributes /t REG_DWORD /d 2 /f
OR
(Remove)
powercfg -attributes 2a737441-1930-4402-8d77-b2bebba308a3 48e6b7a6-50f5-4782-a5d4-53bb8f07e226 +ATTRIB_HIDE
3. You can now close the elevated command prompt if you like.
