Kernel Power 41 code 63, help please.
2023-03-18T23:38:37+00:00
Most recently, I ran into a problem, namely, that during the game my computer freezes tightly. After looking at the action log, I found there critical errors Kernel Power 41 with code 63. I tried everything, and reinstalled Windows, and checked the RAM for errors, and everything like that, nothing helped. Through the sfc /scannow command, 4 corrupted files were found, they were installed, but the error still remained. Please, please help me!
    2023-03-19T01:35:01+00:00
    Please confirm that there were/are continued BSOD despite replacing the Intel chipset drivers.
    While playing Warzone 2 at random times, the computer freezes tightly and only restarting through the button helps. Therefore, yes, I confirm that after installing the drivers, the problem was not fixed.
    2023-03-19T01:34:47+00:00
    Here is the link again.
    https://www.intel.com/content/www/us/en/downloa...
    Cindy
    Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2023-03-19T01:32:57+00:00
    2023-03-19T01:29:17+00:00
    This appears to be fine.
    The minidump shows the reason why a computer crashes. In this case, it showed the problem was the Intell processor. Please run the link above to see what is causing the processor problem.
    Cindy
    I apologize for my stupidity, can you please point out the link again where I need to go. If you are talking about a processor test, then I did it and above indicated a link with the result of the test.
    2023-03-19T01:10:53+00:00
    Cindy
