how do i fix my wifi/drivers problem and Bluetooth
2024-07-28T07:48:28+00:00
i just built my pc and i got a pc protector app I'm not really sure what is was called but it installed a Wi-Fi driver for my pc before i could not use Wi-Fi only ethernet and when i tried to download my motherboard drivers it installed but it didn't change any thing i tried a lot of different ways for the drivers to work but not a single way worked anyways i have Wi-Fi now but it cuts out a lot when I'm playing a game or just idle and it happens mostly when I'm playing a game ere and i want to fix this but i don't know how to if someone could help me id really love that here my specs B650 Aorus Elite Ax AM5 motherboard CPU Ryzen 5 7600x operating system windows 11 home and also i can't connect any Bluetooth devices to my pc
  1. DaveM121 936.1K Reputation points Independent Advisor
    2024-07-31T06:30:49+00:00
    In Device Manager, what is the exact model number of the WiFi and Bluetooth devices?
    2024-07-30T20:34:54+00:00
    do i still do this if i have a amd cpu and if i do can you provided a link to the website
  3. DaveM121 936.1K Reputation points Independent Advisor
    2024-07-30T07:49:56+00:00
    Download the Intel Driver and Support Assistant form the Intel website and run that utility to update all your Intel drivers.
    2024-07-30T07:43:02+00:00
    Please just install the most recent version of those 3 drivers, the other drivers do not need to be installed.
    i installed the drivers you said to install and i tested a few games that when i would play it would go out but i played them for about almost an hour and the internet didnt go out but the bluetooth i still cant connect anything to my pc
  5. DaveM121 936.1K Reputation points Independent Advisor
    2024-07-30T06:13:03+00:00
