Is there a solution to fix my cursor lock when using Xbox game bar?
2024-07-17T00:07:24+00:00
So for a couple weeks (about 3 weeks now) anytime I use xbox gamebar on windows 11 to join a party to talk to some friends, my cursor lock on all applications would break making my mouse cursor go to another monitor when working on something or playing a game. This still happens when the application is fullscreen or borderless full screen. I confirmed it is the xbox gamebar as I have no other problems with cursor lock when I don't use the gamebar. All my updates, drivers, and apps are up to date and repaired/not broken. currently I'm using a app that will manually lock the cursor to a screen, but would rather not need to do so. Hopefully this is enough info, if not I can clarify more.
Windows for home | Windows 11 | Gaming
    2024-10-26T21:16:25+00:00
    same issue i have been having open game bar close game bar and the cursor goes to different monitor only way iv fixed it was reinstall windows 11 but had an update today and it has come back microsoft support won’t do anything about it
    2024-10-26T13:37:50+00:00
    Anyone find fix for this ? i tried installing older version of Xbox nothing changed still same issue !
    2024-10-25T00:52:11+00:00
    Really need a fix for this asap.
    2024-10-19T15:33:29+00:00
    That’s what I’m trying to figure out this happened outta the blue and never had a issue until now. I just get the cursor lock off glitch when I try to play with my friends on Xbox or try to talk to them!
    2024-10-18T18:37:13+00:00
    When can we expect an update to this? Gamebar is in an unusable state currently. Mouse cursor lock being broken makes all games unplayable while using gamebar.
    Anyone official care to comment on this issue?
    Loads and loads of people are reporting the same issue here and on reddit.
