Hello everyone,
Found this post really useful as I have the exact same issue as numerous people have detailed in this thread. I think I may have found fix for it. I repaired all three of the apps above and then I went on to fix the Microsoft Visual C++ using a separate thread on another issue as detailed below:
“Lester BernardReyes
Replied on July 5, 2024Report abuse
Hi Charles, thanks for reaching out. My name is Bernard a Windows fan like you. I'll be happy to help you out today.
I understand the issue you have, there is nothing to worry I am here to help, this error is due to a Visual C++ runtime library error and it can also be caused by the incompatible display driver, in this case, the first thing you need to do is to uninstall and reinstall the game which is having an issue as it will automatically reinstall runtime files required for the game, if the problem persists, you may follow the steps below:
Repair All Visual C++:
Press the Windows key + R and type:
appwiz.cpl
Then press
OK Right-click each Microsoft Visual C++> Click Change> click Repair
Note: Do this on all Visual C++ Restart the computer and check”
