This means that I will send it to technical support
I need help. My graphics card isn’t found in Device Manager, replaced by Microsoft Basic Display Adapter with error code 31. Is the card possibly damaged? There should be an NVIDIA GeForce RTX 2050."
2024-11-28T16:01:21+00:00 -
DaveM121 936.1K Reputation points Independent Advisor2024-11-28T15:59:40+00:00 You are trying to update the drivers from inside Windows, that will not work, because Windows cannot recognise your graphics card, you need to download drivers from the Nvidia website, if you cannot get a driver to install, then you will need to get your hardware checked at a PC Repair Shop.
DaveM121 936.1K Reputation points Independent Advisor2024-11-27T18:55:12+00:00 Okay, I will be here.
2024-11-27T18:53:41+00:00 Ok , good bye
I will wait you tomorrow
