Usually it is BIOS not reporting to Windows that there is an Nvidia card on the PC, have you checked in BIOS for the graphics settings.
I need help. My graphics card isn’t found in Device Manager, replaced by Microsoft Basic Display Adapter with error code 31. Is the card possibly damaged? There should be an NVIDIA GeForce RTX 2050."
2024-11-27T16:10:14+00:00 What is the main cause of all these problems?
DaveM121 936.1K Reputation points Independent Advisor2024-11-27T14:00:27+00:00 Usually you can get into BIOS by starting your laptop and repeatedly press the F2 or Del key on your keyboard, do not change any other settings in BIOS, just look for a setting to disable the integrated graphics.
2024-11-27T13:58:20+00:00 How is that?, please details
DaveM121 936.1K Reputation points Independent Advisor2024-11-27T13:48:40+00:00 Boot your laptop into BIOS, is there a setting in there to disable the integrated graphics (iGPU), to try to get Windows to see the Nvidia graphics card?
