KMODE_EXCEPTION_NOT_HANDLED help?
2024-11-21T07:46:57+00:00
  • <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
  • <System> <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" /><EventID>41</EventID><Version>8</Version><Level>1</Level><Task>63</Task><Opcode>0</Opcode><Keywords>0x8000400000000002</Keywords><TimeCreated SystemTime="2024-11-21T07:37:07.3471937Z" /><EventRecordID>56135</EventRecordID><Correlation /><Execution ProcessID="4" ThreadID="8" /><Channel>System</Channel><Computer>DESKTOP-NV14JER</Computer><Security UserID="S-1-5-18" /></System>
  • <EventData> <Data Name="BugcheckCode">30</Data><Data Name="BugcheckParameter1">0xffffffffc0000005</Data><Data Name="BugcheckParameter2">0xfffff8027a9177e5</Data><Data Name="BugcheckParameter3">0xfffffc888ccbdb18</Data><Data Name="BugcheckParameter4">0xfffff8027e68b920</Data><Data Name="SleepInProgress">0</Data><Data Name="PowerButtonTimestamp">0</Data><Data Name="BootAppStatus">0</Data><Data Name="Checkpoint">0</Data><Data Name="ConnectedStandbyInProgress">false</Data><Data Name="SystemSleepTransitionsToOn">0</Data><Data Name="CsEntryScenarioInstanceId">0</Data><Data Name="BugcheckInfoFromEFI">false</Data><Data Name="CheckpointStatus">0</Data><Data Name="CsEntryScenarioInstanceIdV2">0</Data><Data Name="LongPowerButtonPressDetected">false</Data></EventData> </Event>
I was suddenly gaming when my PC suddenly crashed with the error code KMODE_UNHANDLED_EXCEPTION_CAUGHT. I do not know what caused it.
    2024-11-24T18:39:49+00:00
    I have installed the AMD Drivers and have used Driver Verifier again and have not blue screened again, will continue to monitor.
  2. DaveM121 934.5K Reputation points Independent Advisor
    2024-11-24T18:31:35+00:00
    Glad to help!
    2024-11-24T18:26:25+00:00
    Thanks, I am currently re-installing AMD Chipset Drivers
  4. DaveM121 934.5K Reputation points Independent Advisor
    2024-11-24T07:34:46+00:00
    That new minidump file indicates the AMD Chipset drivers caused that crash.
    Go to the support page for your PC or Motherboard on the manufacturers website, then from there, download and install the version of Chipset drivers they recommend and while there, if you do not have your drive encrypted with Bitlocker, check for any BIOS update that may need to be installed
    2024-11-23T17:38:56+00:00
