KMODE_EXCEPTION_NOT_HANDLED help?
2024-11-21T07:46:57+00:00
  • <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
  • <System> <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" /><EventID>41</EventID><Version>8</Version><Level>1</Level><Task>63</Task><Opcode>0</Opcode><Keywords>0x8000400000000002</Keywords><TimeCreated SystemTime="2024-11-21T07:37:07.3471937Z" /><EventRecordID>56135</EventRecordID><Correlation /><Execution ProcessID="4" ThreadID="8" /><Channel>System</Channel><Computer>DESKTOP-NV14JER</Computer><Security UserID="S-1-5-18" /></System>
  • <EventData> <Data Name="BugcheckCode">30</Data><Data Name="BugcheckParameter1">0xffffffffc0000005</Data><Data Name="BugcheckParameter2">0xfffff8027a9177e5</Data><Data Name="BugcheckParameter3">0xfffffc888ccbdb18</Data><Data Name="BugcheckParameter4">0xfffff8027e68b920</Data><Data Name="SleepInProgress">0</Data><Data Name="PowerButtonTimestamp">0</Data><Data Name="BootAppStatus">0</Data><Data Name="Checkpoint">0</Data><Data Name="ConnectedStandbyInProgress">false</Data><Data Name="SystemSleepTransitionsToOn">0</Data><Data Name="CsEntryScenarioInstanceId">0</Data><Data Name="BugcheckInfoFromEFI">false</Data><Data Name="CheckpointStatus">0</Data><Data Name="CsEntryScenarioInstanceIdV2">0</Data><Data Name="LongPowerButtonPressDetected">false</Data></EventData> </Event>
I was suddenly gaming when my PC suddenly crashed with the error code KMODE_UNHANDLED_EXCEPTION_CAUGHT. I do not know what caused it.
    2024-11-23T17:06:10+00:00
    I just realized how annoying getting my computer to crash 3 times will be, considering it realistically only crashes once a day...
  2. DaveM121 934.5K Reputation points Independent Advisor
    2024-11-23T08:16:38+00:00
    Glad to help!
    2024-11-23T08:02:13+00:00
    Will try this tomorrow, thanks.
  4. DaveM121 934.5K Reputation points Independent Advisor
    2024-11-23T07:54:55+00:00
    To try to force Windows to show any faulting drivers, the best option would be to turn on Driver Verifier, let your PC crash 3 times, then you must turn off Driver Verifier, and finally, upload any newly created minidump files
    Before you run Driver Verifier, please create a new System Restore Point
    https://answers.microsoft.com/en-us/windows/for...
    Note, if you have any difficulty getting into Windows with Driver Verifier enabled:
    Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
    Do this twice
    On the third start Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt... etc.
    Go to Troubleshoot - Advanced Option - Startup Settings and click Restart
    Upon restart, press 4 to enter Safe Mode
    Open Command Prompt as Administrator and run these two commands, then restart your PC.
    verifier /reset
    verifier /bootmode resetonbootfail
    2024-11-23T07:53:17+00:00
    0: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * *******************************************************************************
    KMODE_EXCEPTION_NOT_HANDLED (1e)
    This is a very common BugCheck.  Usually the exception address pinpoints
    the driver/function that caused the problem.  Always note this address
    as well as the link date of the driver/image that contains this address.
    Arguments:
    Arg1: ffffffffc0000005, The exception code that was not handled
    Arg2: fffff804181177e5, The address that the exception occurred at
    Arg3: fffff8041e0737e8, Parameter 0 of the exception
    Arg4: fffff8041e08b920, Parameter 1 of the exception
    Debugging Details:
    ***    Either you specified an unqualified symbol, or your debugger   ***
    ***    doesn't have full symbol information.  Unqualified symbol      ***
    ***    resolution is turned off by default. Please either specify a   ***
    ***    fully qualified symbol module!symbolname, or enable resolution ***
    ***    of unqualified symbols by typing ".symopt- 100". Note that     ***
    ***    enabling unqualified symbol resolution with network symbol     ***
    ***    server shares in the symbol path may cause the debugger to     ***
    ***    appear to hang for long periods of time when an incorrect      ***
    ***    symbol name is typed or the network symbol server is down.     ***
    ***    For some commands to work properly, your symbol path           ***
    ***    must point to .pdb files that have full type information.      ***
    ***    Certain .pdb files (such as the public OS symbols) do not      ***
    ***    contain the required information.  Contact the group that      ***
    ***    provided you with these symbols if you need this command to    ***
    ***    work.                                                          ***
    ***    Type referenced: ExceptionRecord                               ***
    ***    work.                                                          ***
    ***    Type referenced: ContextRecord                                 ***
    ***    work.                                                          ***
    ***    work.                                                          ***
    KEY_VALUES_STRING: 1
        Key  : Analysis.CPU.mSec
        Value: 2078
        Key  : Analysis.Elapsed.mSec
        Value: 4039
        Key  : Analysis.IO.Other.Mb
        Value: 10
        Key  : Analysis.IO.Read.Mb
        Value: 1
        Key  : Analysis.IO.Write.Mb
        Value: 39
        Key  : Analysis.Init.CPU.mSec
        Value: 609
        Key  : Analysis.Init.Elapsed.mSec
        Value: 72440
        Key  : Analysis.Memory.CommitPeak.Mb
        Value: 111
        Key  : Analysis.Version.DbgEng
        Value: 10.0.27725.1000
        Key  : Analysis.Version.Description
        Value: 10.2408.27.01 amd64fre
        Key  : Analysis.Version.Ext
        Value: 1.2408.27.1
        Key  : Bugcheck.Code.LegacyAPI
        Value: 0x1e
        Key  : Bugcheck.Code.TargetModel
        Value: 0x1e
        Key  : Failure.Bucket
        Value: AV_afd!AfdTLSuperConnectComplete
        Key  : Failure.Hash
        Value: {619a5fb7-7c85-ecb6-3062-8585889ba681}
        Key  : Stack.Pointer
        Value: PRCBException
        Key  : WER.OS.Branch
        Value: vb_release
        Key  : WER.OS.Version
        Value: 10.0.19041.1
    Apologies, this is what I had sent.
