Mapped Drive will not connect after reboot
2020-07-24T15:46:02+00:00
After a recent windows update I have had multiple issues with my network drives on my home network.  Some of these were caused by my router which I have replaced.  Now I have all but one drive working correctly.  I cannot figure out the one remaining problem.
If I map the drive by the name (\MyBookWorld\Public) the map works OK until I reboot.  After reboot, I get the error of "The Specified network name is no longer available".  I cannot connect to drive via start>>run either.  If I try to access the drive by IP address using start>>run, it works.
If I disconnect the map drive and reboot, I can connect from start run to the drive after every reboot.
If I map the drive by IP address, reboot and then try to use the drive, I get "Microsoft Windows Network:  The local device name is already in use".  Net use shows the drive disconnected and has an entry to the unc name.  It works if I use start>>run to the UNC name.
I have verified that smb is enabled on the machine.  I have made sure the services of "comptuer browser", "LanmanServer", and "LanmanWorkstation" are set to automatic start.
I have removed the mapping, made sure that it was not in the net use list in the command prompt and made sure the registries at HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2 for this drive have been removed.
I have added the mapping to the Hosts file.
I tried mapping to a different drive letter and get the same problem.  Any ideas on what in Windows is messing this up?
    2021-05-06T12:03:16+00:00
    I haven't been able to find a solution since September.   Well one was to restart 2 times and that would work.  But had a user yesterday couldn't access the drive even after reboot 3 times.  I couldn't even disconnect the drive explorer would hang.  Even tried net use to delete the drive nothing.
    So since I could browse the path I added to quick access and she was able to access it that way, while the mapped drive to same location still didn't work.
    Then I stopped Workstation service as you said, then started it.    Instantly I was able to access all the shared drives including the already mapped drives to nas.   Then I restarted 4 times and at no time did I lose access.   It's so strange that restarting the PC didn't have the same affect as stopping this services and starting it up.   It must clear something when stopped.
    2021-05-04T07:24:09+00:00
    "..Or it will be mapped and throw an incorrect password the first time they try to re-connect, which is causing AD accounts to become locked after some many "Bad" password attempts."
    I guess the VPN account of your offsite user are same as NT account but password is not the same which will cause AD account locked out.   change the VPN account name will make it works.
