Mapped Drive will not connect after reboot
2020-07-24T15:46:02+00:00
After a recent windows update I have had multiple issues with my network drives on my home network.  Some of these were caused by my router which I have replaced.  Now I have all but one drive working correctly.  I cannot figure out the one remaining problem.
If I map the drive by the name (\MyBookWorld\Public) the map works OK until I reboot.  After reboot, I get the error of "The Specified network name is no longer available".  I cannot connect to drive via start>>run either.  If I try to access the drive by IP address using start>>run, it works.
If I disconnect the map drive and reboot, I can connect from start run to the drive after every reboot.
If I map the drive by IP address, reboot and then try to use the drive, I get "Microsoft Windows Network:  The local device name is already in use".  Net use shows the drive disconnected and has an entry to the unc name.  It works if I use start>>run to the UNC name.
I have verified that smb is enabled on the machine.  I have made sure the services of "comptuer browser", "LanmanServer", and "LanmanWorkstation" are set to automatic start.
I have removed the mapping, made sure that it was not in the net use list in the command prompt and made sure the registries at HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2 for this drive have been removed.
I have added the mapping to the Hosts file.
I tried mapping to a different drive letter and get the same problem.  Any ideas on what in Windows is messing this up?
    2021-04-26T08:36:02+00:00
    Hi!
    Yeah the new Synolgy DS1821+ works flawlessly.
    My old DLINK NAS DNS-345 not so much!
    I got this message today when trying to map it.
    Found this information: Microsoft
    And this information from DLINK: DLINK
    Meaning that my old NAS does not Support SMB2 and I have to activate it in Windows, See DLINK link how. Most likely after each windows update it seams too, as Microsoft deems it nessecary due to SMB1 not being safe enough.
    2021-04-26T01:14:22+00:00
    20H2 made it worse
    2021-03-26T16:22:28+00:00
    I just started getting users reporting this issue. It sees the 2004 and 20H2 updates broke our mapped drives. These are users offsite that connect to VPN and then click their mapped (but disconnected drives) and it reconnects because the password was saved. Now it either removes the drives on a reboot and it's simply not mapped anymore. Or it will be mapped and throw an incorrect password the first time they try to re-connect, which is causing AD accounts to become locked after some many "Bad" password attempts.
    I've tried the above Registry key:
    HKEY_CURRENT_USER\Network\x (whatever letter your mapping the drive too)
    "ProviderFlags"=dword:00000001 (32 bit d-word / hex value 1)
    This does not work for us. The only workaround so far, is put a batch file on the desktop with the "net use" command to map the drive with /PERSISTENT:NO. Then after a restart, the user joins VPN and double clicks the batch file to map the drive.
    2021-02-23T02:52:26+00:00
    I have updated some computers to 2004 and simply adding the provider flags to the letter and a reboot has resolved the issues
    located the Computer\HKEY_CURRENT_USER\Network\Z (what ever your mapping drive)
    please try it. hope you are Lucy~
    2021-02-19T05:20:03+00:00
    Blair, thanks. Of all the things I've tried, that seems to do the trick for me. Cheers.
    That's interesting too, as I would have thought the Workstation service would be stopped on PC shutdown and then restarted on boot-up - same as manually stopping and re-starting while live. Hmm...
    Edit: This was working for most of a week, then my Win 10 PC stopped seeing the NAS shares again. It's like something timed out, but I don't know what reset it in the first place. I tried restarting the service again but no difference this time. I also tried adding the ProviderFlags entry below, but no difference. Back to the start... Sigh.
