Win 10 Build 2004 issue with Realtek audio
2020-06-29T14:39:38+00:00
I upgraded my PC to build 2004. I found my realtek audio is not working at all. HDMI audio was working. But my speakers were not working. I reverted to my old build 1909 and audio started working. Is there any bug in build 2004? When will that get resolved?
    2020-09-22T23:11:06+00:00
    Guys (in reply to all).
    Clearly MS does not monitor nor care for the statuses you post here unless you are successful in talking to some one that can open an Incident, and even then (like me) there is no guarantee you will ever get a response (3rd. request already sent).
    So for the ones that can, and for the tests I ran, burn an ISO from 1909 or 2004 built and install a fresh version of Windows, by the time it finishes, you will have MS audio drivers and working ports.
    Good luck.
    2020-09-22T19:22:50+00:00
    I've not managed to get it working properly, the only useful thing I've found that after uninstalling and reinstalling drivers that the mic stops completely.  But then running the HP audio control and switching the input from my voice to multiple voices and back makes the Mic work again but it is very quiet even at maximum gain.
    2020-09-22T13:49:15+00:00
    I have same issue: Realtek driver: 6.0.8955.1
    Windows home build 19041 10.0.19041
    hp pavillion i510300h
    No audio hardware issue (just ran hp test from bios) it's a compatibility problem with last windows update as stated from hp assistance. They can't fix this but proposed me to reinstall windows (****).
    It's incredible that in 2020 there are such issues. Neither in 1993...
    If anyone could help it would be great
    2020-09-18T15:21:03+00:00
    I have an HP Elitedesk 800 g1 which have been updated from 1903 to 2004 and since then, the microphone from my headset connected to the 3,5mm jack is not working properly, recording sound is very very low, almost inaudible. Sound through speakers are working fine.
    I have tried the drivers supplied by Microsoft and from Realtek with the same result. Prior to that, when that desktop was at release 1903, everything was working fine.
    I also have an Asus Laptop, release 1903 and the same microphone/headset work just fine with it. This upgrade or maybe a patch that come with it has created this problem.
    Sadly, i cannot rollback to 1903 since it's been more that 10 days.
    2020-09-17T19:33:10+00:00
    What are saying about MS driver? What is that?
