my pc keep crashing tried many solution nothing worked im still getting black screen/BSOD
2020-09-22T00:47:20+00:00
hello
(before i say anything what u will read right here is the same on a thread i posted before and im doing new post bcs my problem didnt got fixed)
my pc is  still new a year and half now
but for a long time im getting alot BSOD
tried to  fix the issues  with many methodds nothing works i even opened one thread here about the problem and nothing worked for me
and the thing  that its happening to me its soo weird im having the weirdest PC ever
here is whats going on
so i login  to my pc doing work playing games watching youtube etc...
everything fine then BOOM all of sudden my pc crashes and restart by its on
and then everything is fine im it didnt crash anymore
and then i restart my pc  or close it for different reason and then  when i use it everything is fine  then BOOM bsod and its restart and everything is fine after
and also sometimes when i get bsod
there  a precentge to collect information about the crash
sometimes it went 100% and restart everything is fine
but sometimes its stays at 0% and then it restart BUT guess what happen i get black screen this msg i forgot what it said exactly but its something like this ( pls reboot insert a proper boot device ) something like that
but when i reboot by ctrl + alt + del to restart im having the same msg. so what i did i just turn off my pc by
the boot button wait couple of min then boot again and everything is fine again  i login i go do my work THEN BOOM  my pc crashes and restart by its own then it wont crash again incouple of days if i didnt close my pc
so  what i mean by all of this is
when my pc restart by it own there will be no another crashes for couple  of says then it will crash
but when i restart or close my pc annd open it  by my self and then the crashes happen again  until it restart on its own to work fine
and so what i do i just open my pc wait for it to crash and restart by its own and so i work fine without crashes and when im done i keep my pc open so i  dont have to open it by myself and crash all over again
and thats happen to me for long time i was battling with this ****
i just dont know  **** is going on
tried alot of **** nothing works
sry for the long msg
(and   i posted a thread like this before it in here
https://answers.microsoft.com/en-us/windows/forum/all/my-pc-keep-crashing-and-im-getting-alot-of-bsod/eb936ddf-4bec-4476-bb8d-aecf286a107c
or check it on my profile)
and i have gtx 1660ti
i5 9600k
16g ram
ADATA ssd
WDC
    2020-10-07T09:31:18+00:00
    hello PCR
    (1) i did use DDU unistall and then i install the latest nvidia driver. same problem
    (2)i cant show you bcs there is no report bcs i did a factory reset so there is no blue screeen report ( but most of the ones that i did was critcal process died )
    (3) huh intsersting im starting to get hardware error again
    before i was getting it then it stopped and now it came back
    2020-10-06T05:05:33+00:00
    (1) You did the DDU uninstall, but did you also install the latest Nvidia driver as Greg suggested?
    (2) Show us another NirSoft Blue Screen report to see whether it is the same.
    (3) Show us Reliability History. Does it mention "hardware error" again?
    2020-10-05T23:25:13+00:00
    hello greg how are you doing
    its been long time ive been waiting for your to help me more
    but u havent respond yet is everything ok ?
    2020-09-29T12:33:48+00:00
    im still getting the same thing same crashes same bsod
    2020-09-29T09:21:09+00:00
    umm
     after like 5 min since i sent the prevoius msg
    i got crash
    huh
