my pc keep crashing tried many solution nothing worked im still getting black screen/BSOD
2020-09-22T00:47:20+00:00
hello
(before i say anything what u will read right here is the same on a thread i posted before and im doing new post bcs my problem didnt got fixed)
my pc is  still new a year and half now
but for a long time im getting alot BSOD
tried to  fix the issues  with many methodds nothing works i even opened one thread here about the problem and nothing worked for me
and the thing  that its happening to me its soo weird im having the weirdest PC ever
here is whats going on
so i login  to my pc doing work playing games watching youtube etc...
everything fine then BOOM all of sudden my pc crashes and restart by its on
and then everything is fine im it didnt crash anymore
and then i restart my pc  or close it for different reason and then  when i use it everything is fine  then BOOM bsod and its restart and everything is fine after
and also sometimes when i get bsod
there  a precentge to collect information about the crash
sometimes it went 100% and restart everything is fine
but sometimes its stays at 0% and then it restart BUT guess what happen i get black screen this msg i forgot what it said exactly but its something like this ( pls reboot insert a proper boot device ) something like that
but when i reboot by ctrl + alt + del to restart im having the same msg. so what i did i just turn off my pc by
the boot button wait couple of min then boot again and everything is fine again  i login i go do my work THEN BOOM  my pc crashes and restart by its own then it wont crash again incouple of days if i didnt close my pc
so  what i mean by all of this is
when my pc restart by it own there will be no another crashes for couple  of says then it will crash
but when i restart or close my pc annd open it  by my self and then the crashes happen again  until it restart on its own to work fine
and so what i do i just open my pc wait for it to crash and restart by its own and so i work fine without crashes and when im done i keep my pc open so i  dont have to open it by myself and crash all over again
and thats happen to me for long time i was battling with this ****
i just dont know  **** is going on
tried alot of **** nothing works
sry for the long msg
(and   i posted a thread like this before it in here
https://answers.microsoft.com/en-us/windows/forum/all/my-pc-keep-crashing-and-im-getting-alot-of-bsod/eb936ddf-4bec-4476-bb8d-aecf286a107c
or check it on my profile)
and i have gtx 1660ti
i5 9600k
16g ram
ADATA ssd
WDC
    2020-09-28T16:05:39+00:00
    The problem is caused by the Nvidia Display driver.
    Completely remove the driver by using DDU here:
    https://www.guru3d.com/files-details/display-dr...
    Then install the latest Nvidia Display driver from here:
    http://www.nvidia.com/Download/Scan.aspx?lang=e...
    https://www.nvidia.com/Download/Find.aspx
    Is the display device a separate card or a chip on the motherboard? If it's on the motherboard then contact them to find the driver.
    2020-09-28T15:56:39+00:00
    im not sure if thats what you want but i hope it is
    i followed the steps look
    idk is this what you want?
    2020-09-28T15:33:22+00:00
    I gave you a tutorial for how to run Nirsoft Blue Screen viewer. Please follow the steps it gives to interpret the Blue Screen crash file. If you need help then post it's results back here, not the raw file that isn't useful yet. We need to know what NirSoft says first.
    2020-09-28T07:36:19+00:00
    hello greg
    i had to go it was late for me
    anyway
    idk what u want me to give u in the bluescreen viewer
    but i'll assume that u want something like this
    first this the dumpfiles i assume
    these two are the latest mindump that has ben " saved "
    the reason why  isaid savee is bcs
    bcs i get alot of bsod but
    like i said in the thread that sometimes when i get bsod it wont collect info it stays at 0%
    and it always happend when i get the bsod of ( critcal_process_died )
    everytime when i get this bsod that has the reason ( critcal_process_died ). my pc cant collect info its stuck at 0% and then it kick me out in the in to the boot screen when i see my motherboard company and then i get msg like this
    to escape from that i need to shutdown the pc then open it again
    if i restart from this msg it wont work it  will get me back to this msg
    so i have to close it then wait a min then open it then everything is fine  until i get bsod or the pc restart on itsself
    that always always happend when i get ( critical proccess died bsod )
    anyway thats what i got so far
    hope that helped alot
    2020-09-28T00:20:34+00:00
    See here how to run Nirsoft Blue Screen View:
    https://www.thewindowsclub.com/how-to-use-blues...
    (Avoid ad links, especially avoid Restoro ad!)
