Hi there
Please try the steps on this site:
Worked for me finally ☺️
Meg
when in Zoom both the sound and my microphone randomly auto mute. I can unmuted them using f5 and f8 buttons but it will later auto mute again. There appears to be no pattern to the amount of time it stays on. Sometime 1 minutes sometimes as many as 10. I do not use any other meeting platforms so don't know if this is a Zoom problem or a microsoft problem. I am using an HP probook computer that is less than 6 months old. In Microsoft 10 software.
Hi there
Meg
Thank you so much. I am having the same issue, i have followed this advice however Zoom isnt featured under the apps to give permission to and so i cant press the toggle, help please?
Thank you! I will try this.
Hi, I was having the same issue across zoom and google meet.
So far this seems to have fixed the issue:
Hope this helps :)
Hi All, I was having the same issue across zoom and google meet.
Hope this helps some of you :)
