update 1903 sound problem
2019-03-23T14:32:25+00:00
I have just updated to 1903, and have lost all sound. I have a Creative Audigy2 ZS Pro, yes, I know it's old, but it was working perfectly on build 1809.
After this 1903 update, no sound, so I went back to 1809, and hey presto, I got my sound back. I then tried the very latest 1903 build, but lost the sound again. Have MS got an answer? I will have to go back to 1809 if I want to hear anything, but can wait a day or so if anyone at MS can give me a solution.
    2019-06-11T22:04:06+00:00
    just because it says it is the latest update doesn't mean it isn't corrupted.   Reload the software.
    2019-06-11T21:58:45+00:00
    Driver software is available on their website.  Go to Help,technical support.
    2019-06-11T21:26:06+00:00
    I have a audigy 2 zs
    2019-06-11T21:15:22+00:00
    I just had the same no sound problem after the 1903 update.  I tried many things and nothing worked.  I went to the Creative website and downloaded the software for my card and restarted the computer.  This fixed the problem.
    Hi, what soundcard do you have from Creative?
    2019-06-11T20:20:55+00:00
    Its the built in realtek on my asus prime z270-a. I tried reinstalling the software I had, downloading it from the ASUS website, as well as downloading it from the realtek website. At this point I'm probably going to buy a soundblaster ro Amazon. I have plenty of PCIE slots and this way I can just avoid the problems with the integrated sound card.
